nrk
Just decided to do a runtime test. With a freshly charged AW RCR2 I got 4.5 hours on low. I really love this light. ;-nrk
nrk said:Just decided to do a runtime test. With a freshly charged AW RCR2 I got 4.5 hours on low. I really love this light. ;-nrk
fore said:Newbie, any news yet about the second runtime test on low with your production unit?
I, too, really like the beam on the CR2-Ion. When I compare the beam to that of an Inova X1, the flood of the Ion makes the X1 beam look like it's burning a hole in the (white) wall. The Ion really is better than most other lights for close distances, especially for reading in low light conditions, a very common task.bwm said:...
What a difference! "White wall hunting" they seemed to have the same area of coverage and brightness. But out on that porch where the HDS was bright in a central area and then had a dim corona almost equal to the coverage area but of the CR2 Ion but the CR2 Ion was much brighter over the whole area of illumination.
The more I use this light the more I like it and think it was a purchase well worth making.
Brian
europium said:I, too, really like the beam on the CR2-Ion. When I compare the beam to that of an Inova X1, the flood of the Ion makes the X1 beam look like it's burning a hole in the (white) wall. The Ion really is better than most other lights for close distances, especially for reading in low light conditions, a very common task.
I really like my X1 and the Inova Microlights too, but I think they could be improved with floodier LEDs. Yes, even the unreflectored 5mm LED in the Microlight seems like a spot compared to the CR2-Ion beam. It will be interesting to see LEDs from Cree turn up in other flashlights in time, perhaps some in different colors. And I might get another CR2-Ion if it had a nice floody red LED.
Newbie, I am interested in your runtime of the production unit on low. Other informal runtime tests that I've seen mentioned here on CPF seem to indicate about 40 hours, give or take few hours. My informal runtime test resulted in 34 hours constant output on low, and then I wasn't able to check the light again until the 44 hour mark, at which point no noticeable light was coming out the front (but the LED inside was still glowing).
CroMAGnet said:Just tried some ProGold with a fresh Panasonic CR2. No flicker so far.
