Light Sabre
Thanks Tubrbo DV8. I was going to reply to his message, but have been working lots of OT and wasn't going to respond to it until tonight but you beat me to it. You also said things better than I ever could. :thumbsup:
Per your reply below, we agree on the above GREEN statement.TTA, when you point your finger at someone, remember there are three fingers pointing back at yourself. I think your comment above indicates you are becoming too strict a disciple of your own "rules." I think you go a little off the dogmatic deep end when you state to use "the highest current that terminates properly and doesn't overheat the cells."...
Which, again, is what I've been stating all along....And the BC-900 does run hot at higher rates since it does not have nice, wide cell spacing like the C9000. How hot the cells run during charge also depends on ambient temperature. If I try to charge four tightly-packed Eneloops at 1000 mA on my BC-900, in my laundry room in the middle of summer when it is 90 degrees F in the room, the cells will try to blast past 127 degree F and the BC-900 will halt charging until it cools down...
...The spacing of AAA is wider than AA, so heat does not become an issue as it can with four AA at 1000 mA. Maybe you charge in a nice cool room, and heat never becomes an issue at 1000 mA...
*IF* 700mA OR 500mA OR 200mA *ALL* TERMINATE PROPERLY, by all means, use whichever one you prefer, keeping in mind:...Charge your cells at the HIGHEST CURRENT that TERMINATES PROPERLY and DOESN'T OVERHEAT the cells. Plain-and-simple... If you want a slightly FULLER CHARGE, lower the Charge Rate a notch. *IF* they then don't terminate properly, too bad. Either raise it back up a notch, or use a timer, or *TOSS* / RECYCLE those cells.
...I also have a few ROV AAA Hybrids that failed to terminate at 200 mA, so now I just charge all the ROV AAA at 500 mA...
...Light Sabre states that he has been using two BC-900's to charge his batteries at his stated rates for four years with "no problems whatsoever." If his cells are terminating properly at 700 mA or even 500 mA on the BC-900, why should he use 1000 mA?
...But Light Sabre's cells are in good enough shape to trigger end-of-charge signal at 700 mA for AA or 200 mA for AAA, to imply he is somehow ignorant and demonstrating near-abuse to his cells by not charging at a higher rate is simply ludicrous.
I have a bunch of Duraloops that I've been measuring on my BC900 - I ran them all through one charge-discharge-charge cycle, and then started measuring capacity. Most are in the 2.4 - 3 amp hour range...
So, Light Sabre,Thanks Tubrbo DV8. I was going to reply to his message, but have been working lots of OT and wasn't going to respond to it until tonight but you beat me to it. You also said things better than I ever could. :thumbsup:
So what?...I also did a experiment of charging the cells at 200mA. I set it for the night and woke up the next day and the display all 4 cells says full...
...So I am guessing version 35 might of fix the 200mA termination problem.
All I'm saying is that sometimes reading your posts is sort of like reading a can of PB Blaster. But hey, the stuff does work, so who am I to argue with it?BUT, has he, or *ANY* of the other "200mA Slow Charge Aficionados" *EVER*:
- Posted their results from 'THE EXPERIMENT'?
- So, Light Sabre,
- Have you run 'THE EXPERIMENT'?
Mario, you be a perfect candidate to perform a short test lasting about 20 minutes to confirm the validity of a battery/charger test that I'm running on this forum. In your case, you have known termination issues with your charger and thus you should find that ratio of charge put in is much higher than the charge taken out. The test illustrates how to calculate the partial discharge in mA-Hr..
. all i know when i charge partially charged cells it does terminate and sometimes terminates between 200-700mah has been put into the cells, depending how much cells were discharged.
PeAK
They could have changed the item number to 9009 and left the color the same. The p/n on the bottom of the case clearly indicates what it is. This would prevent any shady returns.
Are you implying you know of other differences then the previously discussed color of the unit's lower case half?
could it be possible that the different color plastic is cheaper to manufacture or easier to source? Even if it just saved them a penny a unit it would add up after a while.
