LilKevin715
Just a quick update it appears Olight will be coming out with a new light featuring this emitter. The new model is called the SR95S UT, some preliminary details of the light can be found on batteryjunction's site.
OK, the efficiency of this LED is SO BAD that it seems I have been wrong - it really only makes sense if this is a full substrate, and the circle is formed by electroplating those contracts on top to shadow the edges of the die.
Indeed. I figured as much. It is to be sure a less than elegant solution. And that min is about the kindest thing as I can say about it. They clearly could have ablated the active region underneath the gold pad and had a thin gold current spreader run along the side there instead of that massive block.
I saw someone is coming out with a flashlight using this LED. :fail: After fully testing this LED in different setups I wouldn't let this anywhere near something bearing my name.
Have any of you thought about making a small insert with a 12v computer fan that could be placed between the body and the head of an SR90/95 to keep it cooler and allow you to run it closer to the before mentioned 60W mark? It seems like to me the new SR-95 head would take quite well to a forced circulation system that drew suction from the battery compartment area, and lets face it an extra few centimeters is not going to deter people from that monster. Seems like to me that Luminous is the muscle car of the led world, who cares about its overall performance or waist as long as it puts out a lot of light and looks pretty.
