Today I received my Petzl Pixa 3 from Karst Sports.
I purchased it to be a very rugged backup for caving and it definitely appears that it will serve this purpose very well.
It is a chunky piece of rubberized plastic, a little bigger than I expected, and feels very solid. It really looks like a lot of thought was put into making this a durable piece of gear and they got a lot of things right. The battery compartment is sealed with an o-ring that has 3 ridges, effectively making it perform like 3 o-rings. This, along with the ATEX/HAZLOC rating suggest that this lamp will handle the sort of wet and wild treatment cavers will put it through. The knob to select the different modes is nice and chunky and very easy to manipulate with gloves.
The lamp can be rotated 180' so that the lens is facing backwards, protecting it from an impact that might happen in a caving pack. Even better is the fact that the light cannot be accidentally turned while on in this position. This is a huge plus in my book. It also appears that the battery case cannot be accidentally opened when the light pointing straight ahead during use.
It does have one minor flaw in my opinion. The documentation makes a pretty big deal about how well they designed it to have a wide flood beam on the low and medium settings. However, I estimate that the flood beam is somewhere around 60 degrees (sorry but I left my compass and protractor in my 6th grade math class so I'm not going to measure it exactly). I compared it with a Fenix HP10 and an Energizer Hard Case and both of the other lamps had a wider beam. Ideally, I'd prefer something at least 90 degrees and perhaps a bit more than that for flood.
Lastly, it could be brighter than 50 lumens on high, especially if someone wanted to use it as their primary caving headlamp, but as a backup it is more than perfectly serviceable and still very comparable to lamps we all thought were pretty darn bright a few years ago. And by not going full blast, it will have very long run-time, which is very desirable for a backup caving lamp.
Perhaps Petzl will take all the good stuff from this lamp and make a "Pixa 4" with a separate 4xAA battery pack and 150 lumens on high? Now that would be a stellar piece of gear!!!
In short, this is a great headlamp, mainly for it's use of 2xAA format and very durable waterproof construction. I can see it being very popular with cavers as well as construction/industrial professionals. If you are looking for the brightest thing out there and do not require extreme rugged construction, you might be disappointed. But if you are looking for something that is going to survive incredibly harsh conditions like wet and muddy caves and runs for a very long time on just 2 AA batteries, it's a winner.
Edit: One comment on the excellent beam shots above. You'll see that the spot is not centered at the middle setting. This is not a flaw. It is intentional and functional. You adjust the headlamp so that the spot is pointing straight ahead. This then allows the flood light to be angled toward the ground, allowing the floodlight to illuminate your immediate vicinity while walking while still shining the spotlight straight ahead. I consider this to be one of the most innovative and functional aspects of this lamp. This makes is so that you only need to move your eyes and not your head to see both near and far, and this is especially beneficial for your neck if wearing it on a helmet for extended periods of time.
