I thought this would be a good place to add my Eiger #2 comments and test results. On 28Sept'10 I ordered a Eiger #2 Brass with medium optic and Neutral emitter. I received the light 21Oct'10.
The medium optic is much floodier than I thought it would be, but I like it. I waffled between the Med and wide, but the wide was out of stock. I'm glad it was because the Med is plenty wide. The Med optic beam profile is almost identical to my HDS Ra170 with a SF F04 beam diffuser on it. Most people would describe that as a wall of light or pure flood, but in fact it does have a hotspot that has a very smooth transition to spill with another smooth transition at the far edge of the spill into blackness.
Tint on this "neutral" is not warm at all, it looks more like a cool white then any of the several 4sevens neutrals I've seen. It seems more like a slightly greenish pure white. Not what I was expecting but it looks a lot better than any 5mm LED I've seen though.
Output on #2 is right around 8lms compared to HDS and ARC AAA versions, which is exactly what I wanted. Something slightly dimmer than ARC AAA GS with a longer runtime.
I started test at 10pm with an Arc AAA for comparison. Unfortunately at 7am the Arc was already completely out so I don't know how long the Arc ran. Lumen values are derived from beam comparisons to HDS R170 programed levels.
Results w/ Eneloop Nimh:
Start: Eiger #2 is about 8lm.
9.0 hrs: Eiger #2 is putting out about 1.5lm in bounce test.
10.5 hrs: about .25 lm
11 hrs: about .2 lm
12 hrs: about 0.1 lm
Test stopped at 12 hrs because I could stare directly into emitter and 1% of original brightness seemed like a good place to stop, before I killed my eneloop. Voltage of Eneloop not checked because I forgot to bring my meter to work.
