WildChild
Re: PILA IBC Charger
Yes I am...
WildChild - Just to be clear, you are talking about the Pila IBC?
Yes I am...
I made up some of my own spacers using nuts and bolts.
Hello WildChild,
The proper procedure for inserting a cell into a holder (both for charging and for using) is to insert the cell, then turn it in place about 1/4 turn. This breaks up any oxidation at the contacts and minimizes resistance issues.
You still have to clean the battery contacts from time to time, but it goes a long way toward minimizing resistance problems.
Tom
Hello Flashlight Aficionado,
Here is the spacer I use for R-CR123 charging...
[image]
this is used in combination with the supplied spacer that comes with the charger.
The one for 10440 cells is the same style, but is a little shorter and is used without the supplied spacer.
Tom
Hello Legendcpf,
Tom
Hi Tom,
Thank you very much for the info, I learned a lot.
I cannot determine from the pictures if it will charge AW's 14670 without nipple. It's not a dealbreaker, I just want to know if I should purchase a magnet.
Thanks again,
Kurni
Hello Legendcpf,
I believe Flashlight Aficionado answered your question.
Basically, I charge until the green light indicates that the charge is complete. I also happen to set a back up timer to remind me that I have cell charging, but I don't use this as the primary charge termination. It is just a back up reminder.
I set that timer for (1.5 * capacity of the cell)/ charge rate.
Tom
