Hello VanIsleDSM,
While it does have some drawbacks, the Pila IBC charger is about the best "off the shelf" cheap charger available.
It is actually designed to charge Pila cells, which are protected against over discharge. If one were to only used protected cells with it, there would be no concern with over discharged cells.
I think a Li-Ion charger should reject a cell that is under 2.75 volts and not bother with trying to revive it at all. However, I seem to be in the minority with that opinion. Most cells can be revived from being discharged to a lower voltage, so perhaps my opinion is conservative.
You do bring up a valid point. I addressed this in a earlier post, but it should be repeated. The smallest capacity cell that should be charged on the Pila charger is one that has at least 600 mAh of capacity. Charging a smaller cell, especially if the cell has been over discharged, exceeds the recommended 1C maximum charging rate recommended by the cell manufacturers.
The idea of heat monitoring while charging Li-Ion cells is interesting. Unfortunately, heat is not a usual byproduct of charging this chemistry. When thermal runaway begins, it usually progresses very rapidly and I am not sure you would pick it up in time to prevent it.
I don't think it is a bad idea to incorporate heat monitoring, I just am not sure how beneficial it actually is.
Overall, with its universal voltage compatibility, and a step down adapter to enable powering it from 12 volts DC, it is very attractive. I agree that it would be nice if it had multiple charge rates, but it does a pretty good job just the way it is.
Tom
