"Practical" Beamshots?
UnknownVT
adirondackdestroyer wrote: "Ok, I really don't know what any of that ment. (Sorry). Can you please explain that to me.
I want to get a Q3 and use Rechargables, if there is anything I should know about different versions of the Q3, that would be nice if you could tell me."
No problems -
didn't mean any of my input to sound (unecessarily) complicated.
Short version -
Both earlier and newer versions of the Q3 appear to work well with the higher voltage - 3.6/3.7V rechargeable RCR123 - as reported on CPF.
Explanation -
the two versions of the (different DC-DC step-up) circuits are essentially by-passed with a battery voltage that's higher than the Vf of the LED -
so the rechargeable RCR123 at rated 3.6V or 3.7V will direct-drive the Q3 -
ie: the circuit(s) are not doing anything and the LED is driven directly by the 3.6/3.7V rechargeable battery - hence the reported substantial increase in brightness levels (and short'ish runtimes of about 30-40mins).
Now note these are the higher voltage - rated 3.6V or 3.7V rechargeable RCR123's in the Q3.
The less common 3.0V rechargeable RCR123 would probably work more like the regular non-rechargeable CR123A batteries.
Cheapo wrote: "So the Q3 gets significantly brighter with R123s?"
Yes, very much so (at least compared to using a regular CR123A in my earlier version - that draws about 700mA) - it is very noticable - so it would seem a pretty substantial increase
- my conjecture - since the 3.6/3.7V rechargeable RCR123 is direct-driving the Luxeon III at about 740-800mA - this is putting about 3watts directly into the LED - without any losses due to the circuit - (unless my understanding about how these step-up circuits stop working is wrong)
UnknownVT
cheapo wrote: "so you own the newer version?"
No, I only have the earlier version of the Nuwai Q3 -
which has the reverse clicky and draws about 700mA on regular non-rechargeable CR123A.
UnknownVT
I realized I've accumulated some more stairs shots in the course of doing reviews.
Bunch of 3watt (clone) single 3.6V RCR123 rechargeable lights from LightHound -
Nuwai Q3 on regular primary 3.0V CR123A
and just to put things into context -
SureFire 9P xenon 3x CR123A
UnknownVT
I have taken more of these stairs "practical" beamshots in the course of doing the comparison review of the River Rock 1.5w 2AA (link) (aka Aurora 1.5w 2AA) - thought I'd add them to this repository.
These beamshots should be directly comparable to each other as they are all taken with the same exposure settings -
River Rock 1.5w 2AA ........................................ Costco 1watt 2AA
Dorcy 1watt Luxeon 3x AAA .............................. Energizer LED HeadBeam - 2x Brighter
and for reference here's a MiniMag 2AA new bulb new batteries -
I've also started another thread on another varient of the practical beamshot - outdoors -
Nuwai Q3 on 3.6V RCR123
please see this separate new thread -
"Practical" Beamshots? pt.2 (link)
UnknownVT
I started to do these more "practical" beamshots because of the more powerful/brighter lights really needed more distance to start showing differences.
In the course of doing the review -
A Classic Revisited - Dorcy 1AAA
a request was made for stairs beamshot using the two different types of Dorcy 1AAA - the original and gen2 reflector type and the latest gen3 focus lens type.
Using my standardized settings for my stairs "Practical" Beamshots -
ISO100 0.6sec f/2.8 daylight white balance - lens set at 28mm (equiv)
showed virtually nothing - if examined closely one can just make out some vague details....
This is obviously in comparison to the much brighter lights I originally started these beamshots for - typically the 3watt Nuwai Q3 (on primary CR123A) and 3D MagLite.
Despite the differences in brightness levels the eyes adapt very quickly and one can see quite a lot even on a single 5mm LED typified by the Dorcy 1AAA.
So I optimized the exposure just to show the difference -
this is giving something like 5x the exposure
at +2 1/3 Stops more exposure than my standardized settings -
ISO100, 3.2sec, f/2.8, daylight, 28mm
The gen3 Dorcy 1AAA using the focus lens does NOT throw any better - unless you consider its spot is larger and a lot more even........
For typical indoors usage the older style reflector based ones - ie: gen1 and gen2 would give more and more useful light - as the reflector directs more light forward especially light that's emitted in directions other than forward. Whereas a lens focusses the already forward light into a spot and basically loses the any light not already going forward.
However the spot is pretty even and light is limited to more or less the spot - which can be a good thing for certain applications - like not disturbing others or not attracting attention.....
UnknownVT
UnknownVT
The Fenix P1D-CE with Cree XR-E has raised a great deal of interest here on CPF -
in the course of reviewing the light - please see -
Fenix P1D-CE comparison Review
I also did some of my "standardized" stairway shots -
Fenix P1D-CE RCR123 High ................................ Cree XR-E in Fenix L1T/L2T RCR123 High
The Fenix P1D-CE seems about the same as the Cree XR-E in Fenix L1T/L2T in these shots -
Whereas outdoors in Post #6 and #12 of "Practical" Beamshots? pt.2 (outdoors)
the P1D-CE seem to out do the Cree XR-E mod L1T/L2T -
I suggested this could be due to the orange-peel/stippled reflector (McR18) used in the Cree mod
A light that was very impressive outdoors was the 1watt Dorcy 3D -
Dorcy 1watt 3D
and just to show its versatility that Cree XR-E mod in L1T using a single NiMH AA -
Cree XR-E in Fenix L1T/L2T 1x NiMH AA
Interesting how throw makes all that difference between indoors and outdoors -
the Dorcy 1watt 3D really makes the case in point.......
UnknownVT
I've said previously I thought the P1D-CE on high may have been brighter than the very bright/intense SureFire 9P - xenon, 3x CR123 (standard P90 module) - so using the same desaturation/removal of color technique - we can compare these "standardized" stairways shots without the distraction of different colors/tints -
Destaurated/Colors removed versions -
vs. SureFire 9P xenon 3x CR123
Some previously spectacular LED lights - LuxIII on RCR123....
Nuwai Q3 with RCR123 ...................................... LightHound V3 on RCR123
Cree XR-E in Fenix L1T/L2T 1x NiMH AA High
This shot is "impressive"
compare it with the previously spectacular 3watt LuxIII on RCR123 above
and the 3D Mag and the Dorcy 1watt 3D below -
and this is the Cree on a mere single NiMH AA battery.....
Here's that impressive Dorcy 1watt 3D compared to a standard 3D Mag -
Flea Bag
Vincent, I'd like to echo other people's opinions that your beamshot methods are excellent! The contrast between the door, white-wall and the multi-colour charts help to illustrate hotspot intensity better any other method I've seen.
Please keep this as a standard! Also, don't move house! :lolsign:
PlayboyJoeShmoe
Shepherd, TX (where dat?)
:awman:
I've been telling myself that the P1 I got several months ago and have been EDCing is all I need....
Then I see real world comparative beamshots of the P1 Cree and I:mecry:
It ain't fair!!!
UnknownVT
4sevens kindly lent me this to play with -
MicroFire Warrior II HID "flashlight" - so I thought I'd take my standard indoors stairway beamshot with it to put things into context/perspective?.....
The standardized exposure was SO bright that is basically over-exposed everything. So I used auto exposure to show the HID illumnination - that turned out to be 1/9 the standardized exposure (or - 3 1/3 stops less exposure)
I also have a 1,000,000 candle-power Spot light -
UnknownVT
CPF member DougS mod'ed some gen4 Dorcy 1AAA's (latest Spot versions) - which I have reviewed in this thread posted in the CPF Reviews section -
Dorcy 1AAA gen4 Mods
Cree Mod Spot ................................................ with reflector head
Stage 2 mod (Spot) .......................................... gen4 Stock (Spot)
on my old fashioned CRT screen I can hardly see the Stock gen4 spot in this beamshot -
The standardized exposure been optimized at a level for a typical 1 watt Lux1, and all the stairway beamshots can be compared directly with each other.
I enhanced the picture without any increase in brightness or contrast - which would artifically boost the apparent brightness - but by grossly over-sharpening the image to bring out the details -
So one can see easily that both the Stage 2 and Cree/stage 3 mods have sigificantly brighter outputs over the stock gen4 - which itself is brighter than any previous generation Dorcy 1AAA (see post#27 above to compare with gen3 and gen1/2 Dorcy 1AAA)
See also CPF thread A Classic Revisited - Dorcy 1AAA for more details and discussion on the Dorcy 1AAA and its generations.
UnknownVT
Standardized stairway shots of the Fenix L0D-CE
(note these should be directly comparable to other stairway beamshots in this thread)
The NiMH appears to be brighter than the plain alkaline - I think this stands to reason - the alkaline is not fresh out of the package - but the one used for the beamshots (only a few minutes) but it probably is just over its initial peak high.
NiMH basically is capable of delivering higher currents for more sustained periods - hence its better brightness despite having a lower open-circuit voltage.
on 3.7V Li-Ion rechargeable 10440 (NOT recommended for regular use) -
compared to the fabulous P1D-CE as a reference (see post #29 (link) earlier in this thread) -
I think we may have a new stairway champ?
Notice that the P1D-CE has a noticably more concentrated/brighter hotspot - so it will definitely out-throw the L0D-CE. The L0D-CE has a much smaller reflector - which spreads its light out more - hence brighter side-spill making it better for the stairway shot.
For the full review of the Fenix L0D-CE please see -
Fenix L0D-CE Comparison Review
swxb12
Bay Area, CA
UnknownVT, this is the thread that got me initially hooked on CPF. Keep up the good work! :goodjob:
