MrAl
Hi there operator_smooth,
Oh ok, 260mT means 2600 gauss, so that sounds good.
I'd be very interested to find out what kind of results you
get from the new parts too. I'd even maybe like to start
a small database where we can store results from
experiments like these for future reference. A lot of
people like this circuit and it would be nice if they (we)
could just go look up the configuration and find parts
that work well without doing too much work. On the other
hand, experimentation is part of the fun /ubbthreads/images/graemlins/smile.gif
Myself as well as others have run circuits without any
input cap at all. You're correct in that the input cap
smooths the pulses through the batteries and that could
make them last longer. Reducing the input pulse by half
would probably be a reasonable goal, so if you'd like
to try that too i can suggest a capacitor value that
will achieve that...i need to know your battery type and
how many in series, and your output current.
Reducing the peaks though the battery makes it easier on
the battery, but i think if your using NiCd's you might
not notice too much difference in run time as this type
handles pulses pretty well.
BTW, on the core calculations,
for a core
OD=10.6mm
ID=5.2mm
HT=4.4mm
with an AL of 740 and 6 turns of wire the sat current
comes in around 0.88 amps. This is fairly close to
your estimate of 1 amp i guess.
Take care,
Al
for a core
OD=10.6mm
ID=5.2mm
HT=4.4mm
Take care,
Al
