etc
This is the dumbest purchase of the decade.
First, I drove for 30-40 minutes to buy the damn thing for $10. 4D Maglite in good shape. It has a burned-out bulb. So far so good, I knew and expected that. Drove home.
Bought the TerraLux TLE-6EX LED drop-in module for 3-6D Mags. What else can go wrong. It does not fit. Actually the module itself does but the tightening collar is too small to fit - to slide over the module and screw into the threads. There is actually an amazon review that explains this in great detail down to using a micrometer. It doesn't fit. I had installed the Nite-Ize module, 3W Mag modules, Malkoffs, but no, not this. It just doesn't.
I decided to dremmel the collar out a bit and did it successfully. Or not, because apparently one of the threads got messed up. Not sure. PUt the module in, the collar over it, attempted to tighten, did so - and no light. Changed the batteries two times. No light. Attempted to remove the collar and during the removal process cracked the whole plastic insides. All the plastic excrement came out, part of the switch I suppose, the spring and stuff. It was going in kind of rough so I used pliers. No-go by hand.
*** I hate the damn thing. What a magnificent waste of time, effort, gas and just stuff. Paid $13 for the TerraLux and it's a waste, since all the Mags I have are non-removable. *Plus* I am now not sure the module itself is good. Perhaps that's the problem. Got it used off your favorite auction. These old Mags are not worth anything in light of the fact you can buy Costco 700 lumen lights, 2 for $20. I got loaded with 2C/3C Mag combo at the BF sale at home depot also for about $10 each.
They cannot be any worse than this stuff. They twist and are really nice overall except the runtime sucks and I expected more lumens than from 2009. The 2AA models they have kick some serious rear end.
Don't buy TerraLux. It doesn't fit in mine. The 4D Mag looks fairly new and begins with D. And No, I don't care to buy another switch, another collar, another anything, I am keeping the LED and the head of the Mag and some rubber O-rings but the rest is going into the trash. 1990's called and they want their Mag back.
Thanks for letting me vent.
