2000mA may be enough for 1/2 D batteries, but watch charging large cells on a -dV terminating charger, the voltage drop may not be fast enough or pronouced enough for the charger to pick up on. 2A into a 3-4AH probably would terminate properly(watch it the first few times!), and if you were to use it with a full size D cell (8-10AH) then I'd be quite surprised if it did terminate on -dV, so a C/10 rate for trickle charge would be more appropriate.A number of people here have built their own adapters to adapt D and C cells to charge in a MAHA C9000. Basically its just a 'dummy' AA cell with wires to an outboard battery holder where you place your cell you want to charge. Charging rates are programmable from 200Ma to 2000Ma. So a half-D should charge in 2 hours to as long as 20.
Or use D charger with a conductive spacer like the earlier post said.
Can anyone recommend a charger that will take NiMH half-D cells?
