LED61
I've loved this light from the moment I saw it in the catalog but it only holds expensive primaries and eats them up fast any experiences with the beam is it worth it?
I have only once seen an M6 attached to a weapon and it was for concept only - not actively used that I recall.h2xblive said:I think of the M6 as a novelty item. Maybe if you used it on your gun, it might be worth it?
Do many people who need to install lights on their guns use an M6? When I see pictures from the military, it seems they use an M2 or M3 or something around that size before they use an M6. Maybe the M6 is more popular with police forces?
Size15's said:I have only once seen an M6 attached to a weapon and it was for concept only - not actively used that I recall.
SureFire certainly make a WeaponLight version of the M6 - the M500B which is a dedicated forend which replaced the handguards of a carbine...
You're right, most WeaponLights usually have two or three SF123A batteries - not six!
The M6 may be a "novelty item" to some but to those for whom it is designed and intended it is an extremely power tool. When you need a lot of light but you can't be carrying a lot of flashlight the M6 is top of the line.
Without a doubt I'd be wanting to buy an M6 after I'd purchased an L2 (in the event that all the flashlights I have disappeared)
Certainly for me there is a big element of fun and play when I use the M6 but there have been situations where it's been extremely useful and indeed I was able to claim for the SF123A batteries I used on company expenses.
One of my M6's is in my everyday rucksack...
Al
The most recent time there was a powersupply failure at work - in the switching room (cupboard basically) the "magic" boxes couldn't decide whether to accept mains power (which meant the lights were on), or backup power (which had run out of juice and which meant the lights were off) - so it was switching back and forth - The room lights and building power was switching on and off quite fast.h2xblive said:Oh, do tell!
Size15's said:The most recent time there was a powersupply failure at work - in the switching room (cupboard basically) the "magic" boxes couldn't decide whether to accept mains power (which meant the lights were on), or backup power (which had run out of juice and which meant the lights were off) - so it was switching back and forth - The room lights and building power was switching on and off quite fast.
The fixit man's flashlight was dead because his charger was at his depot and he'd been out on call for three days. All of the flashlights at work were still dead - a fact which I had discovered like 6 months earlier and written a memo to our Facilities manager to ensure they knew to replace them. They hadn't been.
In asking around for a flashlight I lent the fixit man my M6 (MN20 lamp) which was bright enough to obliterate the flashing overhead lights so he could concentrate on fixing the magic inside the "magic" boxes so the building could correctly decide which power supply to draw from...
Any less light and the flashing overhead lights would have been too much of a distraction - for example the L2 was not bright enough. The M6 was required.
Al
OverLord1 said:I just got my M6-CB a couple of weeks ago after comtemplating the purchase of a $330 light for almost a year. Now that I have it I don't regret spending the cash one bit. The interesting thing for me was that I assumed that I would be using the HOLA and had not even considered using the LOLA on a permanent basis. At least to me, the LOLA appears to be more than 250 lumens and it is plenty bright for any task that I would need a flashlight for. My HOLA is still in the sealed baggie and honestly it will probably remain there for some time.
Ed
LED61 said:Are you afraid you'll never go back to the LOLA?
