Delta
- Joined
- Apr 19, 2004
- Messages
- 432
Getting ready to pull the trigger on a P3D and need to know the real difference (and how much of one it is) between the Orange Peel and Smooth reflectors.
Help?
Help?
Smooth with give you a bit more throw, but a ringy beam, OP will reduce throw and give you a smoother beam with brighter spill and larger hot spot.
So OP gives more of a "wall of light" effect?
Hmmm...tough choice. Still.
For a short while I had a P1D CE with a smooth reflector and a P1D CE Q5 with the orange peel reflector. The lights were really indistinguishable for throw. The orange peel reflector made for a smoother beam. The Q5 and orange peel reflector gave a bigger hotspot and brighter spill which made what I felt was a better beam for hiking as it lit a wide area really well. I sent the smooth reflectored light back.
My vote will be for the orange peel. I'm amazed at how bright the P1D CE Q5 is. You should love the P3D.
I got my P3DQ5 today from fenix store, it's smooth reflector, yes, I requested to swap reflector, throw sure is good (about 3500 lux at 1m), and the dark ring for me is not noticeable, just disappoint with the tool damage in the head surface, I would suggest if you like the smooth reflector and want to prevent the risk of modification, get the light with the smooth reflector that was installed by manufacture
Its that smooth reflector damage from swapping?
+1 Fenix OP is very light. The way I like it!The OP reflector is only slightly textured, so I suspect that the diminution in throw - relative to the SMO - is minimal.
