Hi Linger - Please bear with my long winded answer.
The trick with the Vf is that it is not a "single" number, but instead, it is a curve.
For any brand, or even individual LED, you can make a plot of current on the X axis, and Vf on the Y axis, which will virtually always be an upward sloping curve of increasing Vf with current. This is also true of conventional diodes, not just light emitting diodes.
In order to make it possible to catalog diodes (any kind), manufacturers spec the Vf measurement at some particular current that they choose to target the product for. In conventional diodes, I am pretty sure that the manufacturers sometimes just give the same part different part numbers and rate it for different currents and Vf, to hit different targeted uses.
Power LED makers, such as Cree and Lumileds tend to spec the Vf in the general range of where they expect the customer will use the product as well. In the past, VF was very difficult to control, which is the main reason LEDs are marketed as needing current control drivers. At that time (less than 2 years ago), the construction of the Cree LED on a SiC substrate caused it to have a somewhat higher Vf than the Lumileds LED. Cree made up for this disadvantage with the better thermal and crystal quality of SiC, making life pretty much a draw.
You can imagine that each firm plays up its advantages when it has them, so Lumileds is more forthcoming about Vf specs, while Cree really does not spec it at all, at least the last time I read those spec sheets.
Sorry for this long answer, but it gets away from me.
Please refer to this excellent thread by JTR1962 on white LED testing. Starting approx post 300, there is some truly excellent technical data, curves, etc, where he measured and plotted some "example" Power LED data for output, Vf, etc.
http://www.candlepowerforums.com/vb/showthread.php?t=89607&page=11
It is in this LED section, under "threads of interst", and I think called "white led testing".
The numbers are very real - but - apply only to that specific LED and its exact bin. The difference between Cree and Lumileds for LED performance is really tight - sort of like measuring 2 Olypmic class runners on 3 different races and over 4 days. Which one has lower Vf = the bin is more important than the brand.
So, for one more "dark horse", one of the LED packages that JTR tested was by LEDEngin. LEDEngin buys a narrow bin range of premium Cree die, and puts them (4 die) into their own, quite good package. They offer the package with the die wired in series, or in parallel.
For ease of testing JTR bought one wired in series, meaning those Vf numbers are 4X what they would be if wired in parallel, plus, the current would also be divided by 4, so the Vf is even lower. (in other words, since the current is now divided into 4 die, each is only seeing 25ma)
By my reading of the data, this would indicate that the lowest Vf power LED package he has tested to date, at a load current of 100ma, is the LEDEngin product. (this is the target current posted in one of the discussions above.)
I hope this makes sense - if not, I will try to answer more clearly next time.
Take care,
Harry
