jasonsmaglites
- Joined
- Feb 15, 2007
- Messages
- 980
i finished my 4d dd high vf led mod and it should be putting out 700ma as i tested it with 4 d's and that's what it was getting right off the bat. however the light came on, shone nice and bright with a flood of light, then went down to about the brightness of a fenix eo1, if that. also a light i built 2 months ago, a 2d low vf dd which was nice and dim, with insane runtime (probably) has had flickering problems since about a week after i built it till now. what could i be doing wrong. the only thing i can think of happening is that i am drilling h22s holes a little bigger to fit my wires through and im grounding out the positive since the inside of the heatsink isn't annodized. i really dont think its that since the plastic sleve should be isolating it. and on my 2d, it seems like it is in the switch that the problem is. could i have put too much solder on the switch and found a ground from the positve solder? (by the way, in a mag switch which is + and -, the tab we fold over or the piece down in the center) i can't figure out what im doing wrong. i've had other builds be fine, but some of them are sold and gone, and i have a red 3d here at the house that is beautiful. can anyone offer suggestions for common mistakes for these mag sscp4 builds?
jason
jason
