donn_
Ok...it was a little more work than a true drop-in, but if I can do it, anyone can.
A short time ago, I spent a little time cranking the stock bezel rings off two M3 heads (Z46). This involved a heat gun, strap wrench and one of RPM's removal tools. All in all, it was pretty easy, and I love RPM's Ti bezel rings on the M3.
A day later, I read how Sgt LED installed a D26-sized LED drop-in in his M3, and I decided to try it with a new Lumens Factory D36 Cree R2 drop-in.
Off came one of the Ti bezel rings, and everything in the head...including the stock reflector, the reflector collar, lens gasket and lens.
I put the shock-isolation foam strip back in place, started the drop-in into it from the front, and used the reflector collar to shove it down into place inside the foam.
Once the drop-in is secure, simply re-install the reflector collar
Then the lens gasket
the lens
and the bezel ring
Now you have a nice 250 lumen Cree R2 M3!
A couple of notes:
The spring set on the drop-in is a bit shorter than stock, so I used a 1/16" magnet spacer behind the cells to make contact.
In the removal of the stock bezel ring, I scratched the Pyrex lens. Surefire won't sell these lenses, so I had to find a substitute for the 37.5 x 3.25mm stock lens. Otto Frei's website sells a watch crystal in mineral glass, which is 37 x 3mm for $3.50 plus shipping. It works just fine!
There are other D36 Lumens Factory lamp assemblies which will work just as well, including an incan putting out 700 lumens.
the lens
and the bezel ring
A couple of notes:
