Please see post #16 regarding an issue with my UltraFire charger overcharging my cells.
A little warning for others running the MN16 LA on 2x18650(I suppose this would apply to the MN11 and P91, as well).
Last night I burned out a MN16 LA for the second time in a week.
The first time was using LG 2600mAh unprotected 18650s on a Leef C-C body with a KT2, and a SF Z58 tailcap. The MN16 had 1-2 hours of runtime, though it's impossible to know exactly. Used it, put it down, picked up to use again, dim sick yellow output. Dang.
I'm sure we all know that the MN16 is overdriven with this setup, and that's probably why some of us are using it(me, for example), since it's so bright and white.
Some of us have commented that our high draw lights are brighter with the clickies, and I thought that might have contributed. Also the 2600mAh cells not dropping much voltage into a less than 1C load could have been a factor.
So...I got all smart and stuff before putting in another MN16, and swapped the tailcap for a Z41(the standard SF lockout tailcap), and the LG batteries for AW's 2200mAh protected 18650s. Minimizing the risks, to my way of thinking.
My second MN16 didn't even last 10 minutes total. Same as before. I had used the light several times throughout a evening/night double shift, left it sitting on a table, picked it up to use again, and got dim yellow output.
Both MN16s have a black spot, and the inside of the globes are smoked.
The only other contributing factor I can think of is that I've been using an Ultrafire charger that sometimes charges the cells to 4.25-4.3V, and that little bit of extra voltage may have been the straw that broke the camel's back.
I'm tempted to get another MN16 and try using my old Pila charger for the AW cells, but really don't want to chance frying another lamp "just to see", and will probably just switch to the MN20 for this setup.
Good luck.
oh, and here's a pic
Good luck.
