This is a bright little pod light! I would describe the beam style as similar to my Helios - It very slightly favors a flood style and its transition/cone is extremely smooth versus having a very bright center spot and a noticeably dimmer corona. The VSS-3 is definitely a more collimated beam. To my eye, the Locator beam appears to extend out the same distance as the VSS-3. In the next couple of weeks when I have a new camera, I will take these lights to a better spot where I can actually place the spots on a target over a mile away - or attempt to. I'm extremely pleased with my POD light. For a little fan, it is fairly loud and the casing just below the lens got somewhat hot after about 25 minutes of running. It probably relies on forward motion of the helicopter to help keep it cool. I can't run that fast.
Locator on the left and VSS-3a on the right.
:candle:Just a quick note if you still have the cooling issue. :thinking:
Since the Light was designed to be moving through the air on a helicopter, as you noted, perhaps just mounting or aiming a small cooling fan on the outside, at the areas that get too hot, may allow you to run the light for longer periods of time? :twothumbs Just an idea.
