3D Mag Mod - Mag85 or Malkoff P7???
vrocco
Pittsburgh, PA
I just came across an old school Mag 3D that I would like to mod. What is the better option as far as performance, run-time, price, etc? Building a Mag85 or buying the Malkoff P7 drop-in?
I realize the Malkoff is out of stock currently, but I am willing to wait. If the Mag85 is the better choice, which parts are best and where is the best place to buy them? If the P7 is the preferred choice, which battery adapter are you using to power it in a 3D Mag? What are some comparison specs between both platforms as far as lumens, run-time, etc.
I am new to the whole flashlight mod field. This is my first. So I apologize for the newb questions and thank you in advance for the help.
The price will depend on how nicely you want to build the mag85. Runtimewise the p7 will win hands down but the mag makes up for it with high cri, a nicer beam imho and the ability to start fires.
vrocco, when you say"old school m#g" do you mean incandescent or literally old style. The old M#gs dont have a "D" in front of the serial number and I believe Malkoff P7 drop-in won't fit. I dont know for sure if the currently available heatsinks are made to suit "old" style M#gs either. I'm sure more knowledgable members will chime in and correct me if I am wrong. Good luck with your build.
Pete.
Sorry, when I said "old school", I just meant non-LED, non-high tech type. Incan type.
The serial number does begin with "D". I checked that when I looked at the Malkoff drop-ins.
:welcome:
Which is better, a Mag85 or a P7? That's kind of like an apples an oranges question. For the P7 I don't think you can do any better than the Malkoff dropin. So you've already got that covered. Here's a Shootout where StefanFS made a direct compared between a 50 watt halogen and a P7 MagLite. The classic Mag85 gets its name from the 30 watt Welch-Allyn 1185 medical bulb. Take a look at this re-rating chart for the 1185. It only goes up to 10.56 volts. If you click on the little R for that voltage, you'll see the bulb only has a life span of 16 hours at 1140 lumens. So 3*18650's with a spacer tube and a reworked tailcap spring would be a little brighter than that but with less than 10 hours of bulb life. You could also use 9*AA Sanyo Eneloops in a 3D Mag. A couple of forum members make custom AA holders (1 & 2) for this. Contrast that with a P7 LED that lasts 50,000 hours if you don't overdrive it. By way of comparison the 50 watt halogen bulb StefanFS used puts out 1250 lumens and lasts 4,000 hours. So it's 50% brighter than a P7 and only needs 4 amps at 12 volts.
Until the recent introduction of high drain Li-Ions (1 & 2), driving 100 watt bulbs required a ton of batteries. Lighthound has been selling the rest of AW's IMR line and will probably have the 26500's in shortly. Three of these C cells is about 30 mm shorter than 3 D's. A homemade wooden dowel with a bolt going through it will both make up the distance and help isolate the batteries from the heat. Then you could go with a 64623, 100 watt halogen. For less than $4 the Osram has a 2,000 hour life span and puts out 2,800 lumens. That's more than 3 times brighter than a P7. The downside is with AW's 2,300 mAh C cells, you'll only get a 15 minute run time at full power.
You'll need at the least a ceramic bulb socket replacement for a hotwire. AW's Incan Driver (1 and 2) will take up to a 150 watt bulb. It's both a soft-start to take away some of the start up shock and make the bulbs last longer. And it has PWM levels of 30, 60 and 100%. So the above 100 halogen would get ≈ 45 minute run time @ 30%.
You need a metal reflector (1 and 2) or that much heat will melt the reflector in seconds. KD and DX have cheaper metal reflectors. And you'll need a 52.1 mm Borofloat (Pyrex) lens as well.
LOL :crackup:
... and the ability to start fires.
Nothing wrong with WA's site and its built-in rerater (after all, they should definitely know how to rerate their bulbs!), but AWR built a hotrater spreadsheet by deriving the formulas from their rerater (so it's equally valid) that can be used for WA and other manufacturer's bulbs, and LuxLuthor has done actual testing of all the popular bulbs and some less-popular but promising ones. Best of all, he's presented his results-to-date along with useful data from AWR's hotrater spreadsheet, making this post a one-stop information center on most bulbs of interest; here is the data for the WA 1185.
True, but I'd go with 26700 molicells instead, for longer runtime. :p
A point worth noticing -- that one's an IRC bulb, which can get much higher efficiency than normal bulbs. The coating reflects infrared back in, so the filament can keep the same temperature (and thus light output) at lower power levels. (At the nominal 12V rating, it's making the same efficiency as the 1185 (at nominal 9.6V), but that's only because the 1185 has traded off bulb life to get efficiency and whiteness. The 64440 has tons of life at nominal, so it's got lots of room to overdrive, and the efficiency naturally increases. Check LuxLuthor's tests -- the 64440 can go up to 22V without popping, and gets comfortable bulb life around 30 hours at a more reasonable 18V.)
Sure, but you'll be underdriving it most of its life -- I'd use a fourth 26500 (it'll fit, with a tailcap-spring mod) for a brighter & whiter light, or at least use 2.9Ah 26700 cells instead to boost runtime by 25%.
But really, you can get more output than that 100W 64623 (2800 lum, 106W at 12V, 8.8A) from a lightly overdriven 65W IRC 64447 (60W at 12V, 5.0A, but run it off 4x26500 for 2965 lum, 92W at 15V, 5.6A), and boost runtime by 60% over the 64623 and 3x26500, or 25% over 64623 3x26700. And you'll still get about 275 hours bulb life -- that may not sound like much, but you'd have to change batteries about 700 times first. The IRCs really pay off in runtime, brightness, or both. (And if you want something more like the 1185, with less output and a good runtime, Osram also makes 25W and 35W IRCs, and the previously discussed 50W IRC as well.) But they should all have at least 4 cells for good results, as should most 12V bulbs.
I really thought I wanted an LED until I read the two great posts above.
Now I have ordered AW Incan driver, Borofloat Lens, and Metal reflector. Still trying to decide on a lamp and power.
Thanks for talking me into the incan.
A while ago I ran across this YouTube video of a hotwire making short work of some newspaper. I recognized the flutes in the head as being member cmacclel's handiwork. You can here him say Mac's Customs at the end of the video. It's not really a Mag85. That is in the sense I was trying to explain to vrocco yesterday that while the WA1185 or the ROP may have started the hotwire craze, it sure wasn't the end.
Apparently he got some heat about the 1st vid looking fake and posted another video with shoes so he could step on the fire.:crackup: He says he's using the Osram HLX 64623 100 watt halogen. There are some pictures showing 12*2/3rds AA NiMH batteries driving it. Also it looks like a reamed out MOP (medium orange peel) modamag reflector that's been bored out for the larger halogen. The estimated output he says is 4000 lumens at 14 volts!:wow:
Mag85 can start fires?
Why do I always fail when it comes to stuff like this:shakehead
Even if you do the tailcap spring mod, can you fit 210 mm worth of batteries in a 3D MagLite?
Vrocco You might might want to take a look at this guys site too. Since you haven't decided on what bulb you want yet. The Osram 64623 will be good for among other things, starting campfires.:)
On the other hand, as member Benson pointed out the 50 watt IRC's have a coating on the interior of the bulb. Something I had never heard before. That could be handy if you run halogen bulbs at low power for entended periods. Somewhere I remember reading that while many bulbs might have gases from the halogen family in them, they don't necessarily support the halogen process. At something like 800°C (I don't know the exact figure), the gases in the envelope cause the melted tungsten vapor to be redeposited back on the filament. Part of what gives them their extraordinary life span. The flip side to that is if you run a halogen at low power (say the 30% setting on AW's Incan Driver) for long periods, the tungsten will deposit on the envelope instead of the filament. The silvery film cuts down on the overall output. It's not a big deal as that takes 100's of hours and the bulbs only cost a few bucks.The 64623 and the 64440 are both the same size. So get both types of bulbs and experiment.:)
If I can ask, what kind of reflector did you get? The MOP's correct artifacts in the beam. Me personally, I go for the throw so smooth is better for that. Good luck and keep us posted.:popcorn:
I bought one of the MOP from here: http://theledguy.chainreactionweb.com/product_info.php?cPath=48_56_73&products_id=808
Although, since i hadn't decided on a lamp, I just went with the default opening size. Hopefully, if I need to, I can bore it out larger.
Another smaller snag, I pulled out the mag today to look at it again and realized it's only a 2D not a 3D. So I hate to ask, but what are your recommendations for that??
I guess I can always buy another 3D body for this build and do something else with the 2D. Maybe an LED build.
The Shoppe specifically mentions 0.425" as being the correct ream size for an Osram 64623. Consider that's less than 1/8th inch larger than the standard opening. It won't be too large to use even if you don't have a hunger for anything larger than a standard WelchAllyn bulb, or campfires...
FYI, aluminum reflectors are coated after machining. That is to say it's not a one step process. Consider the Shoppe doesn't guarantee reaming results with regards to chipping and how long they've been selling them vs. the likelihood of success if you do it yourself. Perhaps you can send them an email and ask if it's too late to add to your order? What's another 3 bucks?
Yep -- I actually prefer foam instead of a spring, but you've got about 6mm space for whichever. I have one of these in my hand right now with an 1185 and no head -- I'm still waiting for the metal reflector to arrive for this build, but the "candle mode" of a Mag85 is quite satisfactory, too. :candle:
If you consider the fact that Benson said he put 3*26700 Moli Cells in a 3D, then 3*AW 26500 should easily fit in a 2D. Just on batteries, three of the one compared to the other is 60 mm shorter. And if you take a good look at the picture of AW's Incan Driver vs a stock MagD switch, the AW switch is shorter. That leaves some extra room. So three of AW's new batteries should easily fit in a 2D MagLite.
I've seen a few posts saying there is a certain size of PVC tube at the hardware store that will properly sleeve C cells in a D cell sized light. You'll still have to Dremel away the anodizing on the tailcap to make a proper ground after you come up with a makeshift tailcap spring. That shouldn't represent a major problem.
If you looked at MrMcCracken's batt pack he had 1,400 mAh rated 2/3rds AA NiMH batteries. Even though AW's 26500's have a little less voltage (12.6 volts full charge), they still have a 2,300 mAh rating. Quite a bit more than the NiMH batteries.
There's one other thing to consider. If you live in the USA, you can buy a brand new 2 or 3D MagLite for 20 bucks. That's not much considering the other costs involved. A nice pretty red one will remind you of its newspaper related capabilities.
I have no idea...and I don't have a clue whats the internal length of a 3D mag
I've never gone that far. but if you must you might have to cut the switch assembly somewhat...
I'm sorry for the confusion Illum. That post was to three different people because I was too lazy to make them all separate posts. I was asking Benson in the second part since he thought vrocco should use 26700 Emoli's, if they would actually fit. IMR26700 are according to Moli Energy's pdf exactly 70 mm long. But since vrocco says he actually has a 2D, the point is now moot. Well almost that is.
According to MagLite's website the difference in length between a 2D and a 3D is 59 mm. My 3D's battery compartment measures internally 211.8 mm long from the back of the plastic switch body to the bottom outer edge of the tailcap. That's without a tailcap spring of course. Based on that, 3 of AW's IMR26500 that are spec'd at 50.4 mm long will fit with 1.6 mm to spare. That's a fairly tight fit. The only kind of spring you could fit in the tailcap would be a flat spring with a slight curve in it. AW's Incan Driver is a little shorter than the stock Mag switch. But that's only an eyeball estimate from the pictures. I've never actually had one in my hands to measure.
Still I have to say, imagine a 100 watt hotwire in a 2D Mag with a 15 minute run time.:wow:
I'm curious, what is the usual runtime of a Mag85 configuration, WA1185 on 9AA eneloops ?
Would that do to predict the runtime?
  • WA1185 run on a 9AA NiMH pack => to stick to manufacturer data, that would be around about 10,56v*3,32A = 35W
  • 9AA eneloops => 9*1,2v*2Ah = 21,6Wh
=> 21,6Wh/35W = 0,62h
=> 0,62*60min = 37min
But how does the beam look like after 30min? Around 500 lumens ?
There's a lot of good info here. I think for now I am gonna stick with th 2D I have. I may down the road pick up a 3D and do something different, but for now, I am gonna use the parts I have.
I just bought a few of these: http://www.kaidomain.com/ProductDetails.aspx?ProductId=2751
My question is, what bulb would you recommend running on 2 of those batteries in a 2D Mag to get a decent mix of brightness and runtime? Or would I be better off running 6 NiMH AA batteries instead?
Based on one of threads linked above that shows runtimes for incan bulbs, I am thinking my best bet is:
1. 3854-H 6V 24W Pelican Big D High - @ 8.4v (2 li-ion D batteries) predicted lumens from lux 1572
However, is this a lamp that will fit my two-wire driver? or does it need a socket? I can't tell.
Am I right on reading that? Like I said before, still new at this.
Thanks again for all the help and comments. I am really looking forward to learning this stuff better and doing more mods.
If you go with the 6AA configuration, best for you will probably be to set up a Mag ROP mod.
