U
UnknownVT
- Joined
- Dec 27, 2002
- Messages
- 3,672
Once again through the very kind courtesy of 4Sevens I have a bunch of Preons on hand for this review....
Bunch?
Size:
well at least one in every color plus a Preon 2.
These aren't just colorful (well, the black isn't
) but the finish and anodizing seems to give the surface some grip and even feels almost like rubber......
Head:
The Preons use the Cree XP-G R5 emitter and can be used as a twisty - as supplied or one can get a clicky tail-switch as shown on the titanium version (that's actually 4Sevens' own personal light....) and on the red Preon 2.
The Preons have Strobe, SOS and 2 beacon modes - but one does NOT have to cycle through them nor is it likely that those would be invoked by easy accident.
The best is for me just to show the instruction sheet -
so unless one has a predilection for cycling through modes it would be pretty unlikely to get to these special modes without some premeditation....
I also really like the sequence/order of having Low first then going up in brightness - that's my main complaint about the Fenix AAA series that they start in default medium brightness and I am always switching it to low - so am somewhat dazzled first by the default brightness.
So how does the Preon 1 perform?
vs. Fenix LD01-Q5 Stainless Steel both on Max using NiMH
The Fenix LD01 beam is more concentrated - whereas the Preon spreads its light out more to give both a bigger hotspot and wider corna - so this is hard call to make. On paper the LD01 is rated at 85 lumens max - the Preon is rated OTF 70 lumens max.
vs. Fenix L0D-RB80
here one can see that the Preon is brighter - iirc the Fenix L0D-RB80 was rated at 60 lumens Max?
vs. 4Sevens Preon 2 (2x AAA)
the Preon 2 is noticeably brighter than the Preon 1 - actually their heads are the same - so this is to show the output on a single AAA vs. 2x AAA - the Preon 2 is rated at OTF 160 lumens - that's twice as bright - and pretty impressive for a 2x AAA light.
vs. Preon 1 Titanium - since I have it at hand....
any differnce has to do with LED sample variations - the Ti version seems to have a slightly warmer tint maybe tending just a bit toward green - and the regular Preon 1 appears to be a bit brighter.
All in all the Preon 1 is a very nice pocketable flashlight - the clip (removable) designed for the light and not as an after-thought accessory is actually genuinely usable/useful. A tab for a keyring is supplied so can be used if one does not like the clip, or install neither to get a plain unadorned/unattached light.
INDEX to follow up parts -
Minimum low level compared - Post #15
Bunch?
Size:
Head:
vs. Fenix L0D-RB80
