Hi everybody
Just wanted to share my latest mod I finished:
It's a SF 6P drop in with 4 Rebel 100 LEDs and 4 rebel reflectors (from Wayne). I call it RebP500.
The rebels are direct driven from a 18650 Li-Ion battery and take about 500mah each.
All in all you get roughly 500 LED-Lumens for 1 hour. Not bad for your old SF 6P. Up to now I did no runtime test, so I can't say anything about the heat issue. But I guess for my short time operation up to 10 minutes it should work. And as I use it with a two stage switch it is very versatile.
The beam pattern is (as the reflectors themself) comparable to the SF L4, just way brighter = a true wall of light. I would say to my eyes the hotspot is as bright as the one from my preferred SF L5, just about 4 times larger. The picture of the beamshot does mislead a bit.
Just wanted to share this idea with other modders and encourage them, even if its small: it works. My next idea is a 7 Rebel drop-in for a SF U2 clone.
Dominic
RebP500 on the left SF L5 on the right
Base is a drop-in from DX
Dominic
