Beamshots have been added to the first post. I need to play with my camera a bit. Those don't look so great to me. (Blurry) Maybe I will try again later.
I've run it for up to 5 minutes. At that point the head is almost too hot to touch. The body stays relatively cool.
I have 10 Emoli 16850s in the battery holder and 2 spacers. I can light this thing up right off the charger with no
. I may eventually try a 11th cell but benchtesting shows that these bulbs go pop at or around 43V. I have only tested one though.
I'm using a IRF1404 mosfet for the switch. (It came as part of the Ryobi pack that I harvested the cells from). I don't experience any problems in benchtesting the switch at up to 50 volts and 15 amps so I don't expect to have any problems with the light.
The battery sees about 41 Volts initially and that tapers of fairly quickly. According to my measurements I'm pulling about 13.3 amps off the pack. The cells don't seem to get warm at all.
I desperately need to get myself a FM3V2 head (or maybe V3
). The beam is quite floody due to the size of the filament. It still out throws everything else I have but not quite in the light saber way.
It does produce that cool pillar of blue light that I haven't seen out of any of my lights yet. You can just barely see a hint of it in the beamshot.
A big thanks goes out to all the folks here. This forum has been a wealth of information. :thumbsup:
