well we're not in incan yet, we're just taking about your holder
2S3P = 2 series 3 parallel
2x14500s is 3.6Vx2 = 7.2V [4.2x2=8.4 OCV on fresh cells ]
3 parallel is well...1 stack of 2 14500s yields 7.2V @ 750mah
3 parallel stacks is 750x3=2250mah without losses
so, given that your 6x14500 is a 2S3P holder, you have 7.2V 2250mah to work with
if your holder happen to be 6x14500s configured in 6S1P [or just "series"], you pretty much have 21.6V nominal [25.2 OCV on fresh cells] and only 750mah in capacity...thats a pretty worthless configuration for hotwire lamps:shakehead
AW protected 14500s can take up to 2C of current draw [1C = capacity of battery, 2C = 2x750mah = 1.5 amp draw max] Most hotwire lamps draw at least 3 amps, 3A = 3000mah. 3000/750=4, 4Cs is potentially dangerous using 14500s not to mention a very very short runtime under the assumption that your holder is configured in series.
now, if your holder is what Filippo's referring to 2S3P, then you have to size your lamp within 7.2V[3.6 (nom)x2]-8.4V[4.2 (peak)x2]
but you have 2250mah to work with.
at a maximum of 2C current draw [as stated per AW guidelines] 2x2250=4500, or 4.5 amps max for the holder. The values gives you a general parameter for your lamp...then we can go on to choosing lamps
