Looking at Figure 5 of VM7205 datasheet, and comparing it with Pila IBC circuit board, I figured that replacing the 2W 0.22 ohm ceramic resistor (R1) with a 0.15 ohm ceramic resistor would change the charging current to 1 ampere. Do I also need to raise the power rating of the R1 resistor?
The psu that came with the Pila IBC is already rated 6V and 2A, so replacing it is already sufficient for the job.
Any other thoughts or suggestions?
Are you planning on doing this mod? If so I'd very much like to hear the results, I wouldn't mind my Pila IBC charging at 1A myself as I only use it to charge 18650's, I use my WF-139 to charge smaller cells.
