matrixshaman
I found this light fascinating because of what appeared to be a unique switch although I didn't even know for sure when I bought it if it had a tails switch or just a different lanyard attachment. But it was a Rebel LED and I've begun to really like lights with this LED. It is a Romisen RR-A090 from dealextreme.com and I am very impressed with the quality of machining on this light, the unique and extremely easy to push tail switch as well as the apparent PCB battery connection button. The quality of the light output is very nice also with typical Rebel hint of warm white and very bright. At DX it looked like it had a smooth reflector but it came with a light OP reflector thankfully as the Rebel seems to need that to have a nice output (at least for the white wall hunters). The one drawback to this light would be the ease with which it can be turned on so pocket or purse carry would be a problem without some protector. Fortunately with the shape of this unique switch it shouldn't be hard to find things to protect it. Even the lanyard it came with can be looped around the tail of the switch and that will prevent it from turning on. You will need to use a twisty or small piece of wire or something to keep that lanyard in place under the switch and I'm sure there are many other better options including a hard leather type carry case. I plan on using it by my desk since it is so fast, smooth and easy to turn on - just what I've been looking for. DX lists it as a 1.3-4.0 volt light but since it's battery compartment size is CR123 or RCR123 size -- and plenty of room for the RCR I used - I don't know what kind of 1.5 volt cell you'd run in this - but I think there may be some NiMh sizes that may fit. Pics to follow if all works well - in a few minutes - you really need to see this to appreciate how different this switch is - it's a concave ergonomic dime size head on a stem emerging from the tail if that can be imagined.
