I can think of a couple possibilities.
Your tailcap is loose. Tighten it fully and the incandescent bulb should illuminate. Then loosen it just to the point where the LEDs are no longer on, at that point you an use the tail button to engage the LEDs (light press) or the incandescent (full press).
Your batteries are weak. The A2 doesn't give any warning about low batteries. It just stops the incandescent bulb. My old A2 drops the output before it hits the shutoff threshold, but my 2 "modern" ones do not, they simply shut off. Also important to note that testing battery voltage while resting is not a good indicator of the battery's performance under load.
Your bulb could be burned out. Very doubtful with the time you claim is on it, but is possible. Remove it and inspect. Be sure to clean it with high-percentage isopropyl alcohol after handling the bulb to remove the oil your fingers leave behind.
Good Luck!
