"As of August 2020, Surefire customer service says that the SR07 ST07 switch may not allow the M600DF to run at full brightness when using an 18650 cell."
When I saw this statement, I decided to do a small test.
Using my light meter, check how much the brightness will drop when using the tape switch compared to the click switch.
A light meter cannot detect the ture light intensity of the flashlight, but it can get a relative change in value.
The brightness reduction of ST07 Tape Switch compared to Z68 Click Switch is as follows: (The batteries are brand new or fully charged)
- Surefire M600DF (1x18650): 20% lower
- Surefire M600U (2xCR123A): 22% lower
- Surefire V1 Vampire (1xCR123A): 5% lower
It seems that tape switch just can't handle higher current.
The lower output Vampire did not drop that much.
I also took the Olight Odin to test, the Tape Switch did not have any brightness drop compared to the tail switch, basically zero.
Using surefire's tape switch, it is difficult to achieve the declared lumens, which is quite surprising.
