M@elstrom
As you all may (or may not) be aware, I've been in the process of building up a 4D M@g Hot-wire, being unable to decide on any specific bulb type I've been experimenting with overdriven 20w Osrams (500+ Lumen), not really happy with sub P7 performance from a Hot-wire I began looking for alternative globe types/ratings to satisfy my Lumen addiction... this is when I stumbled across some old generic 55w H3s in my garage (I always upgrade stock lighting) dismantling the outer H3 shell I discovered to my joy that the bi-pin anode/cathode thickness was extremely close to the G4 spec (though admittedly slightly further apart) so I can swap between the two without ruining the high temp ceramic pin retainers! :thumbsup:
Specifications
Anode/cathode diameter - 0.67mm (same as G4)
Spacing between leads - 5mm (Versus G4's 4mm)
Glass capsule 10.12mm - G4's 9.23mm (at their widest point)
Glass capsule height 30mm - G4's 23mm
Using the information/data gleaned from HERE a stock 12v 55w H3 emits (in the vicinity of) 1450L @ 12v, hence @ 14v (11x AA NiMh) the output should be between 2000 ~ 2487 Lumen (oh yeah that makes me feel better!) :devil:
What good is telling you all about it if you can't see it for yourselves? so here you go... what where's the beam shots? they'll have to await litho's reflector & a mineral glass lens
Specifications
