Tool steel will rust in a flash, so some surface treatment (outside & inside) is needed. Black phosphate or black oxide are commonly used, or you can apply a toughened paint like Dura Coat:tool steel(if possible)
I am looking for a host w/switch with the form resembling the 2c mag Maybeelength wise to hold 2 aw c Cells with Large copper heat hink for future muti emitter build. I was thinking a light made entirely of copper would be cool.
Just a guess, but Mac probably quoted copper solid round stock because that's the least expensive way to start. One would need incredible luck to find pipe in a OD & ID combination that would build out in the correct size to hold a pair of AW C cells. This looks like a $500 to $1000 project :eek:copper pipe is cheap(er)
But copper pipe is cheap(er). A light made entirely of copper would be cool if it had a nice patina to it. Copper can be patinated a number of ways and tube/sheet can be worked with hand tools if you have patience.
