Any mods for EO1 or similar light with white LED?
22HERTZ
After carrying my E01 for a while I noticed I tend to use this light much more than any other light I own.
This light is just so convenient to carry (on my keys) I always have it without having to think about it.
This light is almost perfect except for the purple/blue tint.
Some say its not noticeable in real use, and while it is less of an issue it is still an issue for me.
So I was curious is there a light similar to the E01 with a whiter tint?
Are there any mods for the E01 to replace the LED with a better one?
I would think with technology getting better Fenix would update the E01 with a better (whiter) LED even at the expense of run time.
I really love this light, and it has saved my butt a few times during power outages/outdoor excursions, but I never got used to the sickly purple over a long time of owning/using the light.
LOD isnt what Im looking for.
Im looking for everything the E01 is (long runtime, watertight, common AAA, small size, reliable twist on/off)
Only thing I need different is a white LED.
Does a light just like the E01 exist with a white LED?
Um... not trying to be a poopy head or anything but the L0D has long runtime(for low mode), is watertight, uses AAA, is small, and is a twisty
Also check here for some other options http://www.candlepowerforums.com/vb/showthread.php?t=229430
I stand corrected.
I thought I read somewhere it was not watertight.
Ill look into it more.
Thanks for the link :)
You can use some ~400 grit sandpaper and frost over the LED dome. I did this with an Inova X1-V2 and it took the horridly purple spot and blended it with the yellow flood for a much smoother, floodier and whiter output. its still purple overall, but not terribly so.
I did this with a Gerber tenmpo as well.
There were reports of SF-A2 users doing the same.
I haven't tried it with my Fenix E0 though, but it should work with any Nichia LED.
The E01 has a white LED, so I'm guessing you want a whiter one. The E01 isn't that easy to open from what I hear but if you really want to, I heard the Cree 5mm LEDs have a pretty good tint.
As said by Cosmos, the L0D-CE or LD01 might be a good choice.
After researching it doesn't make sense to bother with the E01.
Ill just get something else worth carrying for ED use.
