any substitute for a Noga indicator stand?
unterhausen
I have a project that requires 2, and I'm a little worried about spending the big bucks on it.
There are a lot of knock off copies, but none compare to the real thing. The reason is that the Noga arms lock because a tapered wedge is pulled through matching tapers located on rods inside each arm. This means accurate grinding & heat treating of all the mating parts.
Nice thing about a Noga is that they bring almost full price when sold in lightly used condition on eBay.
Look on page 78 in the link above. MSC lists a number of Noga bases, some with greater magnetic pull than others. The 175# pull is the most popular, and works where lots of other mag bases will not stick.
I looked on ebay for a while too & as Barry said they go for pretty close to new most of the time. I ended up just getting two of them from MSC on a sale day which came out to be a very good price for them. I'd say they're well worth it but then again I've never used a knock style of these before, only used the older style mag bases with the straight arms.
Tons of the clone style on ebay & LMS had a deal on some that had minor rust (not sure if they're still available).
thanks for the input everyone. Who is LMS?
my willpower is weakening....
Local
Metal
Supply, Supplier, Store, Shop, Source
I've never heard a bad thing about Noga, you'll find they can be handy for more than just machining tasks too, you'd be surprised what you can come up with as a use for a strong articulating arm.
Noga's work well for two reasons - the magnet is strong enough to hold without movement, and one knob locks both arms into total rigidity. Lots of knock offs, but I have yet to see one that's even close to the real thing.
Enco has the DG61003 on sale for $86, and the MG61003 on sale for $108. Both those are shown here, with the DG having less length than the MG: http://www.noga.com/pdfFiles/afat.pdf
While I'm not gonna offer an opinion about which is a better value for you, I have used the knock-off Noga base, such as the $20 one from CDCO. Totally functional, not bad, but certainly not great, either...
I ended up ordering a DG61003 today, hopefully it will be here Monday. I got a chance to look at one of the Chinese clones, you can move the arm when it is supposed to be rigid. The Noga I looked at was much better. Life is too short for crummy tools, especially when the good version only costs $90.
The Noga I looked at had the fine adjustment pinned. I'm not sure if that part is going to be a weakness since I didn't get to use it.
when I asked this question, I was thinking there was a Swiss version of this stand, and there is: Fisso
Apparently they are $150 each though
starting to feel obsessive about this thing, but I'm glad you guys talked me into buying it. The cheap $14 w/indicator stand I was previously using is going to be a refrigerator magnet
