GreyShark
- Joined
- Dec 21, 2008
- Messages
- 359
I just ordered a pair of AW's new IMR 14500's with the intent of using them with the SureFire P91 in my C3 fitted with an M2 shock absorbing bezel. I have run the P91 on 2x IMR 16340's and the output is impressive but the draw is a little heavy so I've never tried to use that lamp with the protected 17500's I normally run in my C3.
These new IMR 14500's should have no problem handling the draw and even pack a little more mAh's than the old IMR 16340. Since it's still a relatively small cell I'm guessing there will be enough sag to keep the P91 from going
It's a shame AW is so resistant to the idea of an IMR 17500. Frankly I think the market for this cell is much larger and based on the other batteries in the series it would probably have a capacity of at least 750 mAh's... maybe a good bit more. At least the 14500 is workable as a 2 cell solution in our 3 cell SureFires.
