Stevie
Well, I finally bought the Apex. However, there are just a couple of niggles I have which I need some advice on:
The reflector seems to be mis-aligned very slightly, so the main beam is not quite a nice spot (am I just being picky?). I have had a look inside the lamp - is the reflector glued to the front of the housing? Is it easy to adjust it's position?
The other niggle that I have is that 2 of the 5mm LED's are off centre resulting in 2 small annoying spots of light thrown out to the left along with the flood. The RHS of the flood beam is smooth without these spots.
All I need to do is move these two LED's outwards slightly to cure this. Is this particularly difficult to do?
Would appreciate your comments...
Steve
Steve
