I purchased a Frist Run Arc LS from someone years ago. I remember the seller said something about a switch that changes brightness. When I flip the switch I can't tell the difference.
Is the switch really for changing output & is the switch stock? There's a jumper connected to the Luxeon cathode. Is this supposed to be there? The inductor, is it the same spec inductor that the regular Arc LS converters use?
I tried searching for a while but could find anything.
Thanks
Thanks
