Aspheric Mag/ Leef/ Surefire Mod- BEAMSHOTS
DaFABRICATA
Michigan
This head was bought last year and came with 2 modules for the head to allow switching between incandesent bulbs and LED.
The incan module has a bi-pin socket and an 1185 installed for use with a C3 body and AW soft start switch....Very bright!
The LED module came with an older K2 and a 3 level driver for use with 18650's only.
Being a dumb-***, I forgot about the 18650 and ran it with 2xCR123's...:ohgeez::poof::hairpull:
The LED module sat around until I could think of a cool mod for it.
During last years Michigan CPF get-together, member discoverEDC had a sweeet Mag modded with an Aspheric that totally blew me away..:eek:oo::eek:
Well disvoverEDC came over yesterday and brought his Aspheric Mag with him again.
I had an aspheric lense from a foglight that I've had since I was like 16. I'm glad I kept it for another 16yrs as I FINALLY found a use for it.
We compared my aspheric lense to his and found mine created a more focused beam! That did it!
Lucky for me it fit perfectly inside the Mag head with the addition of an extra o-ring.
At first I used an XR-E that had the entire dome and metal ring knocked off but still worked. The driver still worked but had only one level and didn't run the emitter as bright as it should.
I had an old P7 module run at roughly 2.8A by an AMC 7135 from another mod that was not getting used anymore. The driver was removed and used to run a different Q5 XR-E..:devil:
With the new emitter and driver, the module was MUCH bright than the "domeless" XR-E and the old screwed up driver.
After adding another o-ring before installing the LED module to help space the emitter back enough for proper focus, I end up with a nicely focused beam. I'll try to get some beamshots tonight if it ever stops raining here in michigan.
Beamshot from about 10'
Re: Aspheric Mag/ Leef/ Surefire Mod
Surefire KX2C-Top Pic
Aspheric Mod-Bottom Pic
SF KX2C
Aspheric Mod
Aspheric Mod---------VS.----------Surefire KX2C
Hey Dafab! That is pretty freakin neat! I like the look of it a lot and the beam is really focused! :thumbsup:
Now that is one real search and rescue light. :eek:oo:
Tim,
You are a crazy man :eek: I just read the PM, you stayed up after I left and finished the aspheric mod :thumbsup: (I was dragging the next day)
After revision two with the XRE R2 your asphere rocks; I am now officially suffering from asphere envy :sick:
That is a very nice package with the Leef body and head, much more portable than a 3D Mag.
I am now 100% certain that aluminum channel you gave me will work for the project light we discussed.
Regards,
Walt
