I'm building a constant current load to discharge my 18650's and measure some capacity, based on this schematic, but without good results. I've replaced the MAX480 with any single supply opamp I had laying there, tried TL082, LM358N, NE5532, OPA2228 without getting any regulation. Since I've used dual opamps, I've tried both to leave the second OP connections free or setting it to a voltage follower pointed to 0V.
The mosfet is allways being driven at full +V voltage by the opamp, saturating it and getting all the available current into it, I have been measuring 3 amps off a single AA cell. Can anyone tell me what I've done wrong? traces on the pcb have made using eagle following the schematic both of the first and the second driver, and then double checked before building the circuit, so the problem is not in the circuit board. Some photos and schematics about the second driver built yesterday:
First, the second schematic redrawn in eagle to produce directly the pcb.
http://i44.tinypic.com/2m6sw86.png
second, the pcb artwork drawn following the schematic posted up there.
http://i41.tinypic.com/2wd9gfb.png
and then some construction pics. The driver has been build on a double sided board, any track is perfectly insulated, no shorts have been found anywhere. Top layer is connected to gnd, all needing pins have got a large area of copper scraped off to avoid involontary groundings.
Can anyone please help me to figure out why this circuit is saturating my mosfet and won't get in any way to regulate? I've tried anything. pulling up down the output with two 100k resistors connected to v+ and gnd, setting the second opamp as a voltage follower getting 0V imput to avoid oscillations, but nothing got my circuit into proper regulation. It would be a pretty good circuit, costs like $10 and can deliver a stable current load to measure any capacity... I just don't mind why it's not working :thinking:
