Battery leaked badly on brand new flashlight!
sakurazaka
I just put in some Energizer batteries on a brand new Jetbeam BA20 that I received yesterday. Tested it for awhile and then store it for a couple of hours. During the night I opened the flashlight to have a thorough look and noted that one of the battery was practically sizzling inside and oozing with acid! I did what i could but the damage is as you see below. The flashlight still works but it pains me to see the extent of damage on something new.
I tried the baking soda method but it didn't do a thing. Should I leave it as it is? It shouldn't have any bearing on its lifespan right since it's still working? Or do you think it's possible that I could claim a new flashlight from Energizer?
reppans
Curious what the story is behind the batteries... were they new or a mismatched used pair. To get a leak that bad, and that quickly, it almost sounds like the light was either shorting the batteries at rest, or light was left on. Then the weaker cell went into reverse charge and then blew.
Frijid
USA
my thought was a short
HotWire
I had a similar problem with a beard trimmer. I used a brush dipped in calcium remover (CLR) and then wiped the parts I could not rinse. "Clean as a whistle!" Alkaline batteries are known for leaking. Try eneloops (rechargeable).
sakurazaka
Tried some white vinegar but it didn't worked. Well it was the same brand and type of batteries so I'm not sure what happened there. Batteries is about 1-2 years old since store bought but was unused until yesterday and the expiry date is in 2016. Will definitely use lithium or rechargeable batteries from now on. I never had an Energizer leaked before so I guess there's a first time for everything.
May try some commercial calcium remover but is it safe to use on the flashlight itself?
jorn
Norway
Every alkaleak should come with a warning: not for use in high drain flashlights :)
MatthewSB
OP - sucks that that happened. I learned my lesson with a $2 flashlight so it wasn't a big deal when it was ruined by the batteries leaking. They were good batteries, and it wasn't loaded wrong or left on, they just blew for whatever reason.
Or how about "Not for use in anything you don't want to ruin"
I pay the extra for lithiums in everything I care about (flashlights, gaming computer mouse, etc.).
joelbnyc
NY
Wow bummer.
So NiMh and lithium ion cells don't have this problem?
Do they make non-alkaline aaaa's? I saw an old post mentioning nimh aaaa's but no links
Edit, found these, primary NiMH? They say it replaces an 8 cell Li-Ion laptop battery though, so it must be rechargeable... I wonder if they are sold as individual cells, or wrapped 8pks, if it replaces an 8 cell...
AAAA-300NMWT, Gold Peak, NiMh, AAAA, 1.2 Volt, 300 mAh, Tabs, 1 Pk
http://www.batterygiant.com/Product/AAAA-300NMWT
This is actually version with tabs, so I would think this would work in a klarus mix5...
fresh eddie fresh
I used to have about a dozen MiniMaglites and every one of them got ruined by leaking Duracells (ironically the ones that came with them in most cases.)
JohnnyBravo
USA, Idaho, Boise
I'd contact Energizer and supply photos too. I had an issue w/ a new light that I bought from them. And they mailed a check to me to get a new one. Didn't even have to send photos or the bad product back, WOW! PS. I no longer use alkalines in my lights. Just Eneloop AAs...
TIMEBNDIT
new ignorant guy here, what is the best choice for battery if one does not want rechargeable?
ragweed
USA
I use the carbon zinc batterys & if they do leak they are much easier to clean with baking soda. I do not leave them in the light for extended periods though. I find they are less prone to leakage than the alkalines.
roadkill1109
time and time again...do not use alkalines on flashlights esp those that get stored over long periods of time! well, lesson learned the hard way.
if you must use primary, use ultimate lithium AA's or go Eneloops.
nathan225
I feel your pain I had a preon 2 that I was using alkaline and one day it did not work and when I opened it the battery was leaking all over the tail cap area and I tried to get it cleaned up but have never been able to get it going again . so now I always pay the extra money for the lithium batteries .
