HKJ
[SIZE=+3]Beamshoots from AAA Flashlights.[/SIZE]
This article is part two of my AAA review, part one is here: A look at AAA flashlights..
Here are all the lights I have included, they are (Same sequence as picture): ARC-U, ARC AAA Ti, Killer AAA, Tiablo A1, Streamlight Microstream, LumaPower Avenger GX, Tank 007 TK-701, Leatherman S1, Leatherman S2, Fenix E01, Fenix L0D, Fenix LD01, Maglite Solitaire, Led Lenser P2, Led Lenser P3, LiteFLux LF2X, LiteFlux LF2XT, Peak Matterhorn #1, Peak Matterhorn #2, Peak Eiger, Peak Baltic.
ARC-U is a UV light, the normal version has a beam more like Fenix E01
The first two graphs show maximum brightness from the flashlights and there are large differences between the different lights. Some of the lights has different brightness, depending on the battery used and a diffuser will always reduce the brightness a bit. Note: Peak Eiger #8 has an extreme high brighness with LiIon, this is probably because it goes into direct drive and this high level will be very hard on the light and the battery.
Hre I have change to a log scale and added all brightness settings for multi level lights. LiteFlux has the best coverage, it goes both very low and very high (with LiIon batteries). For a more simple light, with a large range, the Avenger is good, but its maximum brightness is not as high as Fenix L0D/LD01, but they have a less adjustment range.
To get an idea about how far the lights can throw, I have measured the lux (at one meter), a high value equals a good throw. Note that the Led Lenser lights had the highest value when using wide focus!
[size=+1]Maximum brightness[/size]
LiteFLux LF2X NiMH, LiteFlux LF2X LiIon, LiteFlux LF2X LiIon + diffuser
LiteFlux LF2XT NiMH, LiteFlux LF2XT LiIon, Peak Matterhorn #1
Peak Matterhorn #2, Peak Eiger #2 NiMH, Peak Eiger #8 NiMH
Peak Eiger #8 LiIon, Peak Baltic
[size=+1]Lowest brightness, with increased exposure[/size]
Many of the lights has only one level and the picture used here is the same as above, just with increased exposure. For lights with multiple settings, I have chosen the picture from the lowest setting and again increased the exposure.
[size=+1]White wall beamshoot[/size]
These pictures are the 3 picture in the sequence from part one of the review and always of the brightest setting.
Maglite Solitaire, Led Lenser P2, Led Lenser P3, LiteFLux LF2X NiMH
LiteFLux LF2X LiIon, LiteFlux LF2XT NiMH, LiteFlux LF2XT LiIon, Peak Matterhorn #1
Peak Matterhorn #2, Peak Eiger #2 NiMH, Peak Eiger #2 LiIon, Peak Eiger #8 NiMH
[size=+1]ARC-U[/size]
This is an UV light and has not enough visible light to register.
[size=+1]ARC AAA Ti[/size]
[size=+1]Killer AAA[/size]
[size=+1]Tiablo A1[/size]
[size=+1]Streamlight Microstream[/size]
[size=+1]LumaPower Avenger GX[/size]
Low, medium, high:
Low
Medium
High
[size=+1]Tank 007 TK-701[/size]
[size=+1]Leatherman S1[/size]
[size=+1]Leatherman S2[/size]
Low, High:
Low:
High:
[size=+1]Fenix E01[/size]
[size=+1]Fenix L0D[/size]
Low, medium, high:
Low:
Medium:
High:
[size=+1]Fenix LD01[/size]
Low, medium high:
Low:
Medium:
High:
[size=+1]Maglite Solitaire[/size]
The light has adjustable focus, these two pictures show the focus change (The have increased exposure):
Tight focus:
[size=+1]Led Lenser P2[/size]
Wide focus
Tight focus
[size=+1]Led Lenser P3[/size]
Wide focus:
Tight fokus:
[size=+1]LiteFLux LF2X[/size]
The light can use both NiMH and LiIon batteries and has variable brightness, the light also includes a diffuser.
Low, high with NiMH:
Low, high with NiMH and diffuser:
Low, high with LiIon:
Low, high with LiIon and diffuser
Low, high with NiMH, increased exposure:
Low, high with NiMH and diffuser, increased exposure:
Low, high with LiIon, increased exposure:
Low, high with LiIon and diffuser, increased exposure:
Low with NiMH
High with NiMH
Low with NiMH and diffuser
High with NiMH and diffuser
Low with LiIon
High with LiIon
Low with LiIon and diffuser
High with LiIon and diffuser
[size=+1]LiteFlux LF2XT[/size]
The light can use both NiMH and LiIon batteries and has variable brightness.
Low, high with NiMH, incresed exposure:
Low with NiMH
High with NiMH
Low with LiIon
High with LiIon
[size=+1]Peak Matterhorn #1[/size]
Without and with diffuser:
Without and with diffuser, increased exposure:
Without diffuser:
With diffuser:
[size=+1]Peak Matterhorn #2[/size]
Without diffuser:
With diffuser:
[size=+1]Peak Eiger[/size]
#2 with NiHM and LiIon
#8 with NiHM and LiIon
#2 with NiHM
#2 with LiIon
#8 with NiHM
#8 with LiIon
[size=+1]Peak Baltic[/size]
Without diffuser:
With diffuser
Low, medium, high:
Low
Medium
High
Low, High:
Low:
High:
Low, medium, high:
Low:
Medium:
High:
Low, medium high:
Low:
Medium:
High:
Tight focus:
Wide focus
Tight focus
Wide focus:
Tight fokus:
Low with NiMH
High with NiMH
Low with LiIon
High with LiIon
Low with NiMH
High with NiMH
Low with LiIon
High with LiIon
Without diffuser:
With diffuser:
Without diffuser:
With diffuser:
#2 with NiHM
#2 with LiIon
#8 with NiHM
#8 with LiIon
Without diffuser:
With diffuser
