2xTrinity
Anyway, I've decided to compare a few of the flashlights that I have modified:
Ultrafire C2 - this is the one with the HA-III natural finish from Kai. I ended up swapping the ugly purplish emitter, and the stock 1.1A buck driver, with a Cree WH-bin (warmest available) LED left over from another project, and a 800mA buck driver from DX for longer runtime. I also replaced the one-stage reverse clicky with a McClicky forward clicky. Running 2xCR123
Lumapower M1 - Replaced the reflector with an aspheric lens* to maximize throw, and then I lined the inside of the light with reflective tape to recover a little bit of spill. Replaced the two-stage reverse clicky with McClicky, as well. Stock emitter was on the cool side, probably a WC bin Cree. Running 2xCR123Maglite 2D - Anodized aluminum heatsink, micro-puck boost driver (500mA) and Seoul SVO-bin emitter.
Indoor Beamshots
The shots were taken inside, during the daytime, with daylight white balance to demonstrate the color of each beam.
Backyard Beamshots
Taken just after dark. The short palm trees are fairly close, I couldn't conveniently set up a longer beamshot elsewhere. Images show C2, M1, and Maglite respectively.
EDIT:
This is a closeup of the tree, taken with optical zoom and a fixed 1/2 second exposure. Tree is about 70-75 feet from the emitter in this shot.
This is the same tree, showing a side-by-side comparison between a Mag (driven slightly over 1A, double the output of the one above) and the Amondotech N30 HID. That one has a neutral color temp of 4200K which is apparent, even with auto white balance.
* EDIT: I just received a PM that the lens I linked to did not have correct focus. It's possible the lens I had linked to is different than the one I used before -- I physically measured the focal length and diameter, then linked to the lens on surplus shed with those same nominal dimensions (30mm x 15mm) but apparent the 30x15mm lens up there now is significantly changed. Also, my M1 is the old M1, not the tactical which apparently has a deeper reflector -- which might make the 30x20mm lens a better fit)
Indoor Beamshots
Backyard Beamshots
EDIT:
