My Camera is just a 5 megapix ordinary digicam
Can your camera be set to a manual exposure mode? If you cannot tell, it probably does not.
Can you list the manufacturer and model?
Manual exposure is necessary if you want to do a comparison between different brightness modes and/or lights.
When set to 'auto' mode, the camera will measure how much light is coming in through the lens, and automatically decide the combination of shutter speed and aperture (the 2 basic elements which decide the exposure) to get the "best" exposure.
Whether you shoot a light in the dimmest mode or brightest, the camera will try to make them appear the same.
OTOH, if the camera's exposure is set to a fixed setting in manual mode, no matter how bright or dim the light is, you will be capturing the image under the same condition.
The tricky part (if you can call it that), is to find the right exposure which will let you capture both or all brightness you want to compare.
Thanks to digital, you can get a rough idea just by looking at the LCD, and fine tune by checking the pictures.
There are more tips in the The Dark Room. It is not as active as the other forums, and was made quite recently, so you should be able to find related threads easily.
Good luck!
