Not the FM bi pin mag type holder. The Bi-pin Surefire turbo head type holder. Maybe it wasn't FM who made it? I thought it was but could be mistaken.
Basically a MN style turbo head lamp base that can take bi pin bulbs. If you've got that many bodies, there must be some pretty bright bi pin bulb you could use.
I'd be concerned about the lexan too, I had forgotten about that.
The other thing to consider is that I think this Turbo head was designed for the N series lamps, not the MN series. From what I've picked up from Size15, the filament is different, so does not produce the optimum beam when using the new MN series in the old T series turbo heads. I suspect that the difference is minimal though.
