I hope I'm not in violation of topic (best thrower), but have one more note about heat. Yes, nitrolon does not conduct as well as aluminum, I agree.
I ran my G3 again, this time for 50 minutes. It did get hotter. I measured 98 degrees at the point where the module contacts the body. It was 93 on the body.
Those measurements are surface temps. I unscrewed the head and measured 108 degrees on the surface of the brass while it was running! It was too hot to hold in my hand without tossing around, but not scorching hot.
The body is not all plastic, it has a stainless tube which helps conduct heat away from the head.
I measured everything with a mechanical type refrigeration thermometer that was calibrated in boiling water to 212 degrees at 40 feet above sea level.
Nitrolon is not as good as aluminum for conducting heat but it's also not going to melt from a little heat. Done.
