Preface everything in this post with IMHO.
The G2 isa great light but as others have already stated. It has its limitations. Even with an aluminum bezel, it still can't conduct heat away from the LED. I have never seen any data or material spec sheet for "nitrolon", but my best guess is that its a thermal insulator. I can't think of any mass-produce-able, thermally formed plastic thats a
half decent thermal conductor. With that limitation, you are not going to be able to run an XR-E any higher than ~800-900mah for long on cycles.
For
short bursts +1A designs should be OK. But I wouldn't run them longer than 45-60 seconds per burst. FWIW, I have an older XRE DIY build running at 1.4A that has dimmed significantly over time because I did not pay much attention to thermal design when I was setting it up. This was my garage work light and I left it ON for hours at a time (about 70 minutes per 18650 cell). It got very hot in the summer months, in a poor cooling P60 host.
So you are not going to get much throw with a reflector this small and
safe ~800 mah operating currents.
The G2 is better with incans than LEDs for these reasons. I use mine with a solar bezel and a DX:3218 Xenon LA.... happy with the result, although I really need IMR cells to get the most out of it.
