Justin Case
- Joined
- Mar 19, 2008
- Messages
- 3,797
I have some Tenergy-labeled plastic AA to C adapter shells that are slightly too large to fit easily in a C Mag (both old and new versions). They slide in with difficulty and are even harder to remove. My Eneloop adapter shells fit fine, with room to spare (but not so much as to rattle around). I think that if I remove the Tenergy label from the adapter shells, the shells may fit. But the problem is that when I remove the label, almost all of the very sticky adhesive is left on the plastic shell.
Suggestions on removing the adhesive?
Thanks.
Thanks.
