Dr. Mario
- Joined
- Mar 4, 2010
- Messages
- 459
Now that I have recently decided to buy a whole pack rather than rolling it up (even though I have done Li-ion battery packs before), since the load the 12.8 Volts 6 Amps / hour battery pack (BLF-1206W) will be used in is one of my DIY spotlight with the Kensun automotive HID kit (Kensun is a bit expensive option but still a good option as you CAN choose the color temperature of the Xenon metal Halide bulbs and get them as-is, exactly as you have wanted), so I am curious, if anyone have known about it and / or have given the LiFePO4 battery pack a try.
At least this battery pack supposedly has software-defined BMS in it (I will check it out once it gets here, as well as do some interval runtime test as I don't want to leave it on too long in one run as the 35 Watts Xenon metal halide HID bulb gets quite hot).
Just curious if anyone know of this brand and have used the battery pack from them.
