XeRay
Re: BLF GT94 vs HID. LED has finallly surpassed HID in my opinion.
This temperature actually means very little, The "head temperature limits" are the melting point of aluminum , Its the temperature of the LED's themselves, the Junction temperature that matters a VERY LOT. You need a very large "Delta T" between the heat sink fins and the LED's themselves (As well as a very good mechanical (physical) connection for thermal transfer) in order to have very efficient thermal transfer to pull the heat out of the LED's . Once the heat sink warms up you no longer have that "Delts T". With the heat sink fins at 165 degrees you can be assure the LED's are likely above or at least close to 100C (212 F). That's well above whats good for LED's or any circuitry for that matter for long dependable life. This is why on computer CPU's the heat sink mechanism has been directly attached to the top of the CPU and then a fan as well.
There is no way to get the heatsink directly onto the back of the LED's, they are mounted on a PCB (plastic) etc.
How many watts are being drawn from the battery in this situation ? All those watts that end up as heat must go somewhere, much of it is being trapped inside.
As "someone" politically famous (unnamed here) a few months ago said, "it was just a debate (while laughing:fail" when confronted in a video recorded interview for extreme inconsistencies of opinion and position (implying that misleading comments are normal and to be expected in a debate). ie Political "Flip - Flops" positional lies are normal.
Fortunately this debate isn't Political in the traditional sense, but is seems to have gone well beyond the scientific facts of high powered LED flashlight thermal management design. You simply can't ignore the Physics of thermal energy (heat) transfer. Ambient airflow (natural convection) and radiated IR just cant cut it, submerged in water would likely do the job or possibly cool or cold strong winds.
Also you can see that the hottest part of the head is only 165F which is well within its temperature limits.
Haha I like a good debate.
