sosemot728
Many lessons have been learnt about design for manufacture. I am pleased to present my attempt at a 4xXP-G light. I have been trying to perfect a light with styling I like and at a price that is affordable (Think, $69AUD for a base kit) also, it will most likely have a flashlight battery pack option.
About 920 Lumen's @ 1A
Weight: sub ~110 Grams
Dimensions: 50mm OD x 38mm (Major Length, or 42mm overall) TINY!
Heatsink: 18 inch^2 of sink surface area. (So can handle 1.5A)
Completely sealed, double O-Ring and waterproof to at least IP67 (Omron switch)
I know this lumen range is already occupied by numerous many 'cheap' lights, all promising the world. but my hope is that the quality of this light will be significantly higher
Plus, like all my designs, I am taking an "Open-Source" approach. There will be no secrets, no propriety designs just an awesome light! If you ask me nicely, I will supply full engineering drawings!
It will use the most efficient of everything I could find that is readily available and in stock in large numbers.
PCB - http://www.cutter.com.au/proddetail.php?prod=cut950
Optic - Ledil GT4-XE (90% efficiency) http://www.ledil.com/datasheets/DataSheet_GT4-XP.pdf
Driver - Maxflex http://www.taskled.com/maxflex.html
