Re: *Beamshots-Post #36*Build yer own "Battery Vampire" with a P60
I am new here on CPF, so bear with me...
As I under stand it a "Battery Vampire" is a flashlight that will "suck" the last little bit of "elecricity" our of a battery, in this case a 123.
This is a great idea, and I have kinda discovered it a little for my self.
ie, I recently bought a P60 LED bulb.
I knew form using my SF A@ Aviator, that after the batteries would not light up the incandescent, they would still light up the LEDs.
Also a buddy gave me a single 123 light with an incandescent and LED's and the same thing happens, ie the LED's burn long after the incad. bulb will not light.
So My question is How many lumens should a "Battery Vampire" produce.
I have found that the 3 lumens of the SF A2, with the white LED's is more than enough to;
Get up in the night and go to the bathroom.
Look in your pack for stuff.
Walk around a known area.
Read a map, book, etc.
If I wanted to do more general stuff I would want a few more lumens.
While I AM a Flashaholic, I am not a High Tech One.
So I would suggest this, since the P60 series type bulb lights are so prevelant, some Company should make a P60 LED "Vampire Bulb" at X amount of lumens [to be determined by you techies, but I would guess from 3 to 15 lumens], so we could get a little extra from our spent 123's and help save the environment.
I know I would get a dedicated SF G2 or 2 to use.
One for the house, and to take on trips for the motel, and one for the car to read maps.
Or maybe a drop in for the E series SF lights.
Then I could save the batteries on my A2 for "serious stuff".
These "spent" batteries would probably light up the low settings on the current E1L and L1. You guys with those lights let us know.
