Building a red Cree Module
AardvarkSagus
Lower Left side of the Mitten
I am looking to build a red cree module with THIS led and a generic 1 stage P60-ish drop in that I purchased in the past. Am I correct in assuming that all I really need to do is find the correct value resistor to reduce the voltage being supplied to the LED? If so, what resistor should I look for?
Please correct my possibly mistaken thinking. I'm not well versed in electronics.
Thanks in advance.
The red cree has a lower VF than then typical white XR-E so direct drive with a limiting resistor might not be a very good solution. You're probably looking at below 3 volts Vf at max current. Even using one Li-ion you've got pretty a big voltage differential. Using 2 RCR123's you'd be close to double the voltage you need. This is probably a better case for a buck driver. Not sure what would fit a P60 size module though.
For using a resistor here is a handy calculator.
I am already assuming there is some kind of buck driver in place in this module already since the input voltage was specified as 3.6-9v if I remember correctly. 9v would fry a XR-E pretty quick. I haven't measured yet, but I am guessing I just need a resistor to get from ~3.6v down to the ~2.2.
I have used DX constant current regulators with red led's before and it works OK. Pick a regulator that provides the right amount of current and go for it.
Dropping resistor vs. constant current regulator depends on tolerance for change in brightness as battery runs down and voltage changes. Also the regulated version is often good for a much wider range of input voltages.
<p>
And the dropping resistor is cheap and simple. Take your pick.
