Can Pila G2L take a Malkoff dropin or p60?
regulator
I have a newer Pila G2L and would like to get a Malkoff dropin for it. Does this fit? The current Pila Cree module from the factory has both an innner and outer spring similar to what I have seen for the standared P60 but I do not know if a Malkoff will work.
Also, does he make a special module that would run on a single 18650?
Well...the dreelight DI modul works when I place an appropriate washer or a ring of wire between modul and body. Not much of a problem.
